Oil from Air cleaner
847 Views 6 Replies 6 Participants Last post by  dynaglydr
Was putting new Venom covers on my 06 FLSTI yesterday and when i removed the air filter a bit of oil ran out and dripped. Not much but is this any cause for concern. Do a lot of in town riding during the week and wondering if this is caused from bogging the engine at times. Any thoughts? Thanks in advance.
1 - 7 of 7 Posts
Oil particles from crankcase hot air vents. Normal, some oil vapor will travel up and into breather assembly. Over time the oil particles get together creating that famous oil build up. Constant inspection and cleaning is the solution.
Newest style head breathers and enlarge the oil return holes under the breather(06 might already have them) and this to the ground fixed mine.
On my 01 Dyna, I routed both breather vent lines to a tee and then ran a line down under the bike. Some guys put a filter on the 2 lines. Check this link and see the multitude of options, which means it's a common issue.
https://www.google.com/search?q=Har...2Fforums%2Fshowthread.php%3Ft%3D19344;547;588
1 - 7 of 7 Posts
