1 - 3 of 3 Posts
I recently did a large amount of work to my bike to turn it into a bobber, including replace the problematic lower rocker box gasket on the rear cylinder. I now have oil in the intake and it's throwing several codes:
P0107 Map Sensor Open/Low
P0122 TPS1 Low
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
the bike runs fine for a bit but then out of no where it throws the check engine light and begins to run like shit, difficult to keep running and going. I guess I would like some confirmation that I messed up installing the gasket before I start tearing apart the rocker boxes.
08 Sporty EFI 883
Check all gaskets, hoses and clamps to make sure there are no leaks. Check to make sure all wiring related to FI is re-connected correctly. Vacuum leaks and bad/wrong connections are the biggest thing that happens.
Bobby Bobby take a trip to new guy section, introduce yourself.
1 - 3 of 3 Posts
