1 - 5 of 5 Posts
I have a '07 FLHT and want to install a HD oil pressure gauge. It looks like all I need to do is install the gauge and plug it up. The plug is there behind the fairing at the blanked hole. I checked the parts catalog and it uses the same sending unit for both. Does anyone know for sure?
Tire Killer
Just plug it in. It all set up to do.
Road Glide
I bought the kit HD sells with the air temp gauge and oil pressure gauge for my 06, I think the whole job only took 30 minutes. In the kit was another sender unit to be used for earlier models possibly 03 and earlier. One I have noticed is when I turn on the ignition now the oil pressure lamp doesn't come on, when I fire up the motor it flashes and the gauge goes up, perhaps I should switch senders.
1 - 5 of 5 Posts
