1 - 5 of 5 Posts
Hi I have a 94 Dyna fxds-conv my oil pressure light came on I have new oil in her and it has some extra noise in the top end I've only been on a two hour trip ....That's when I noticed the noise in the top end I adjusted my pushrods and that is when the light came on ....I checked the oil all is good in that department I pulled up the push rod tubes and turned the motor over and I was getting oil there ...so I replaced the pressure switch sill comes on ....any input would be appreciated thank you
Need to have oil pressure checked with an analog oil pressure gauge to see what the pump is actually putting out.
May need to replace oil pump pressure spring, or rebuild pump.
Most important, stop running it, until you find out if you have oil pressure. Hopefully you have not ruined anything ....yet.
1 - 5 of 5 Posts
