1 - 20 of 25 Posts
I have a 2005 Sporty 1200c and have read many, many threads on what oil to use. I have a pretty good handle on the better brands but I'm confused about the viscosity. It seem that 20-50 synthetic is the most recommended but my service/repair manual recommends SAE 20-50 above 40 degrees, SAE 50 above 60, and SAE 60 above 80. I haven't seen these heavier weights talked about. So, what's the real scoop on summer riding with temps over 80? Or, will 20-50 synthetic cover all the bases?
Señor Member
I run it in all conditions.
I was hoping for another oil thread. :)
Re-read your manual. You'll see,(if it's the factory manual), they recommend 20w50 above 40 degrees, 10w40 below 40 degrees. If you are looking at anything other than a factory(I E: H-D ) manual, take anything they say with a grain of salt.
Fla Cajun
WTF??????..ya give up on the baby oil...:what? I thought ya liked squeezin the little fellers....:D
I do Phil..... I do. But my trashmen are starting to complain.
Discussion Starter #8
That's what I was hoping for. Thanks guys!!:)
Señor Member
Big John, we're gonna need a full size shot of your avatar, man.
09 Dyna Super Glide
I run 20/50 all year long. That can range from 15 degrees F to 100 degrees F. In the winter 10/40 can make for easier starting, but I have never had a problem with 20/50, no matter how cold it was.
Even thought I can start up my fuel injected 2009 Dyna and ride off as soon as it fires up, in the winter I tend to let it warm up for a while before taking off. I wait until the oil temperature is at least 100 degrees before riding.
Do I need to do that? Probably not! But it only takes a few minutes and I do it anyhow. It makes me feel better knowing that the engine is not trying to pump 15 degree oil through a very cold engine under the load of riding conditions.
Pete
Poser Member # 99
Sorry Chief and Cisco no Blow ups available
Ya both would just get in trouble any way.
ya might slip off and Hurt your Self with all that baby oil
after following all the collision posts you guys had to much fun
LOL.....:rofl:.......:rofl:
Señor Member
Boo! Bad form, sir.
Señor Member
Señor Member
Uh, we're talking about motorcycles, man. Pull yourself together.
1 - 20 of 25 Posts
