1 - 4 of 4 Posts
So I just purchased my first Harley Saturday! It’s a 2007 Dyna Low rider I love the bike! I have a set of the Willie G license plate screws but the bracket on my bike had the screws on it already and looks like they are part of the bracket. Does anyone know if I can easily change out this bracket or do I need to have the existing bolts cut off and drill through the plate holder to use my skull bolts?
Try'n to behave
I'm not familiar with that frame, but no other frame I have seen (not say'n they're not out there) has bolts integrated into the frame itself. Pull off your plate and try tapping gently (at first) on the studs (yes Chief....I said "Stud") and see if they are not just pressed in.
I have the same plate on my 2013 Dyna. It's the lay back lisence plate mount. I'm sure the turn signals mount there as well?
Either way..The screws are attached to the plate with double sided tape.
Discussion Starter #4
yes the turn signals are all tied in to it too, does the back chrome plate come off to get the tape off? because it is solid on the back side. im gona try and take it appart tonight
1 - 4 of 4 Posts
