1 - 4 of 4 Posts
my 99 Sportster 883 custom has a turn signal problem, the left turn signal works fine front and back, but my right turn signal front stays on when activated the rear signal on right does not flash or come on I've changed the light bulb but still does not come on. does anyone have any ideas on how to fix the problem.thank you for your feedback.
Try lifting the seat and make sure there is first no bare wire hitting a ground and also make sure it is plugged into the harness. May have come undone or gotten corrosion in it
try rotating the bulb.had a similar problem with my wide glide,i rotated the bulb until it worked correctly. it may or ay not fix your issue.
bad connection
I would check the wires in the switch, the front connection to the harness and at the rear tail light also - they may not be making good contact -
I had the problem with a turn signal where the wires at the crimped plug end were shorting out from being bent to many times
1 - 4 of 4 Posts
