1 - 6 of 6 Posts
I have a 92 883. I thought I had a bad starter. But when I removed the primary cover to see if it was engaging I found that my starter was working fine. But the ring gear just spins. It does not cause the motor to spin. Can someone tell me is this a clutch problem or what it is? Thanks in advance
That's what I thought. But when I removed the clutch basket the ring gear is still attached. Anything else it could be or am I missing something?
It might still be attached, but did you not see it spinning on the basket when the starter was engaged???
If the ring gear is spinning then I have to assume the primary chain is also spinning. That being the case I suspect there's something amiss with the comp. sprocket assy..
Discussion Starter #6
schmidty you are correct. The chain was spinning. Could you please tell me what to check or do next so that I can isolate the problem and fix it. I am goin nuts here. This is my first Harley,and I have ridden the bike only once. Thank you guys for all your help.
1 - 6 of 6 Posts
