1 - 20 of 24 Posts
I just got a 06 RK & the speedometer doesn't work. I searched & read these forumns for 4 days now & replaced the speed sensor today but that didn't help. Everything else works. Oh & I just checked all the fusses and there all good.I'm Lost???
Terry
Introduction before questions is the best way to get answers. What nip said.
If the odometer works check for codes, the procedure is a sticky in the electrical section. The codes will show in the odometer window. Post the codes here. Checking DTCs.
Discussion Starter · #5 ·
Nip- thanks I'll walk out to shop and check that.
Fritz- 4give me I will introduce myself now..
Schmid- I will get the code while im checking the plug
Thanks gentlemen.....
T
Discussion Starter · #6 ·
Plug on back of speedo is tight... I did my introduction(sorry :))... Code displayed U1097. Appears "Loss of speedometer serial data to ECM"...
I cleared all & started bike then reran the diag & all was "none"
Now how do i fix this problem guy's???
Thanks
terry
By any chance are you running a fuel pak, power commander, or other piggy back fuel controller?
Unplug and replug the connection. Sometimes it gets a little corrosion on the pins & sockets . :)
Please post what you learn. My 06 king has the same problem. Haven't replaced the sensor, have an oversized starter I haven't pulled to get to it yet. Mines carbureted with a dyno tune ignition.
I'll try checking all the plug's.
Kinda used to riding it with out now.
Discussion Starter · #12 ·
unplugged speedometer, blew both sides out & plugged back up. Tightened all grounds that i could find & tightened the ground on battery. Still nothing. Ran diag again bcoz i rode awhile last night & all say None????
T
T
And you are sure the speed sensor is plugged in good (as in making contact ) ????
Diagnostic Tips
For a quick check of speedometer function, a "wow" test
can be performed. Press and hold odometer reset switch
then turn ignition switch ON. Release reset switch.
Background lighting should illuminate,
gauge needles should sweep their full range of motion,
and indicator lamps [battery, security, low fuel (EFI models),
check engine and cruise] should illuminate. Some
lamps may illuminate even though they do not apply to
the vehicle. For example, the cruise lamp may illuminate
even though the motorcycle is not equipped with cruise
control.
If speedometer fails "wow" test, check for battery, ground,
ignition, accessory and speedometer reset switch to
speedometer. If any feature in the speedometer is nonfunctional,
Pull speedometer and have it tested at the Dealer, most likely it is a
bad speedometer .
Discussion Starter · #15 ·
ok i ran that test, the background lights as soon as i push/hold the trip button. Even before i turn the switch on. But the speedometer sweeps & all lights come on. Then i go through holding the trip down in each catagory & all reads "none".....
T
anybody with anymore suggestions before I break down and buy new speedometer. And also is this what everything is pointing to??
Terry
I don't think its your speedometer if it passes the sweep test.
Asylum Inmate
Need to track that speed serial feed from the ECM to the Speedo in the loom. WOW test is saying speedo is ok, it is not getting info from the ECM.
1 - 20 of 24 Posts
