1 - 2 of 2 Posts
The Bad Luck Magnet
I was wondering if is this is even possible to use a Sportster handlebar/riser clamp on a touring bike? I saw one I like to use but want to make sure it will fit.
Mr. James
The bolt pattern will be different. You would have to use both the risers and the clamp to make it work. If the handlebar has knurled areas on it they might stick out a little. I put a Sportster/Dyna riser and clamp set-up on my Softail.
1 - 2 of 2 Posts
