81 - 100 of 133 Posts
07 street glide 103, trued, balanced, pro plug, welded, h-beam rods. Forged high comp. pistons, .30 gasket, ported&polished heads 1.90 intake valve. Flora racing 625 cams, zippers filter, d&d boarzilla pipe. 110hp 115tq.
Well I'm not diggn up the paper but we got 75hp 90 tq on the HD and 103hp 125 on the warrior. For anyone that doesn't know what a warrior is it's a 110" patrick racing set up on a OHV air cooled pushrod yamy in a 650 lb alum chassis. With custom crank work and reduced drive gear. Here's way more powerfull HD's out there, I'm sure.
2012 Road Glide Ultra
255 cams w/ adjustable push rods
Vance & Hines Pro Pipe 2 into 1
SE super tuner
Stage 2 air intake open cover
82.5 HP 107 Ft.lbs before tune w/ generic calibration from Harley
87.4 HP 112 Ft.lbs after tune on dyno and custom calibration.
Ride is greatly improved and power delivery smoothed out.
2013 Slim
Arlen Ness Big Sucker
TW 777 cams
SERT
Vance and Hines Straight Shot slipons.
94.6 hp, 107 torque.
Gotta put 1000 miles on it, then finish dyno tune. ImageUploadedByMotorcycle1429645178.005729.jpg
2003 FLSTCI Dyno Results - SE Stage 2 Kit
95 inch big-bore
SE 2003 cams
SE2 slip-ons
Stage 1 intake
All numbers corrected:
HP: 95
Max Torque: 110
Runs: Awesomely
:bikerguy:
2009 Ultra Classic
S&S Heads
S&S 107 cyl and pistons Oasis Cycles Build
SE stage 1 AC
V&H pro pie Headers
V&H Monster Rounds
Oasis Cycles Tuner
A little clutch slip but Good numbers.
109HP 116 Tourque SAE adjusted
2010 FLSTSE Softail CVO w/585 Gear Drive Cam Dyno
2010 Softail CVO Convertible with S&S 585 Gear Drive, Harley Race Tuner, and S&S Pipes
Max Power = 108, Max Torque 113.8
Notes:
This chart was prior to timing changes, but they did not change Max power/Torque
Increased vibration in floorboards, bars, and rear piston required timing advancement due to poor ignition performance
Excessive heat is still causing timing breakdown, looking ways to cool the bike, investigating OilBud cooler. Open to ideas and feedback
Tune, intake and exhaust...
Don't have my sheet in front of me, but installed power commander, and they mapped it, V&H power header and air breather, other than that completely stock motor, gained 4.3 hp and 4.9 in torque...cant remember the actual numbers, AFR at 13.8-1
Indecisive Member
A baseline of my bike. Arlen Ness Derby Sucker, V&H slipons, and a pc5
Reactions: OZman
