I have an odd situation that maybe someone out there may have knowledge of. I ride a 75 FLH, and its been great even with various mods, including a B grind andrews cam, and solids. the trouble began when I swithched to Crane solid lifters, and pushrods, (there were some aftermarket solids and pushrods in it prior to this.) along with new lifter blocks. since then, the torque has been lame, and the bike has no pull to it. I had it tuned, and timed by a shop, and the problem is still present. With Crane solids, the cam has to come out, so the lifters can go in, as the pushrods are too long to install with the lifters in, and heads on. the timing marks on the pinion, cam, and breather are all as they should be, so what am I missing? a compression test indicates 132 psi frt, and 130 psi rear. it has a dyna S ignition system, so no points.
Any ideas as to whats going on? I would appreciate any help. Thanks, T-Head.
