1 - 6 of 6 Posts
Just curious guys... I bought a WOLO horn for my sporty, to help in further annoying people. Instructions say to make sure there's a 10 amp fuse in the horn circuit "to prevent damage to the vehicle." Does such a fuse exist in the horn circuit? I bet alot of you tech guys could answer that question relatively quickly. :) I'd check the manual myself to see if there's a schematic, but i'm not too awesome at reading schematics.
You should be OK, the horn circuit, on a Sportster is the assc. circuit, which is a 15 amp fuse. As long as the horn switch is heavy enough for you horn, no problem.
Harley Rider
You should be ok but you might still want to add an inline fuse to be safe.
Really no reason for an inline fuse. The manufacturer is only concerned about the fuse being large enough. The 15 amp protects the wiring, and that's what is important.
Discussion Starter · #6 ·
Bummer. Damn thing didn't fit between the frame. ARGH! Oh well... back to JP Cycles it goes!
:fitz
1 - 6 of 6 Posts
