1 - 8 of 8 Posts
I need a rcm solenoid the solenoid just clicks and once in a while it will let the reverse solenoid kick the starter solenoid ,but it won't kick the breaker out.
What's the battery static volts measure ? Should be at least 12.8v across the terminals.
somebody makes a starter button that fits on the end of the starter.this bypasses all safety stuff.
09 tri glide parts man. p/g. 31 item 23 solenois repair kit 31604-06
item 24 sol. assy 31631-06 comes with 31688-90 & 316689-90
and on pg 145 a item 11 hi-current relay 31595-09
Wayward Son
^First thing to check.^
somebody makes a starter button that fits on the end of the starter.this bypasses al safety stuff.
Have seen them and like the idea for several reasons.
Exaample on Dennis Kirk site.
But in this case it seems like more of an incorrect band aid then a proper fix.
But I like them as a back-up and a nice little trick touch.
Wayward Son
Doing the a little research on trike specific RCM solenoids.
He asked else where too. Got basically the same answer. Check all connections.
Do`t throw good money out on a part when it may not be the problem and the fix may be as simple as checking a few connections and battery voltage.
Good advice.. :thumbsup :)
1 - 8 of 8 Posts
