Rebuilding 95 dyna rear master cylinder. Seems you have to buy the whole cartridge body as one piece. Can not buy the o-rings by their self. Hardware store time? Are they something special that dot 5 won't eat? Bore and plunger look good. Had good pedal and stopping when used. Was leaking at push rod end. Small flat spot on o-ring that seals the plunger inside the body. Would not think it is any special kind of rubber. Same as cal. piston boot? Thanks for any replies.
