Did you install the ballast module ?I swapped out my bulbs in my marker lights to LED's on my '13 Street Glide. Now the red key light on my speedometer stays on. The bike runs fine but the light will not go out.
No, I guess i should though.Did you install the ballast module ?
I just ordered the Badlands Load Equalizer. I will update as soon as I install it. Thank you for the information.OP's 2013 SG still has the TSM/TSSM not the BCM so I think OP needs a module like a Badlands or Kuryakyn load equalizer. The Badlands module from J&P #381-877 for $65.99 would work IMO. Oh and it's plug n play too.
I agree, as I would have ordered the package together and avoided the issue.What gets me is that these companies sell those LED kits but don't advise to use a load equalizer. But In some instances the equalizers aren't required as with the newer Harleys with BCM lighting controllers. The BCMs only need to be reconfigured for LEDs is all, no additional parts or modules.
What year did that change?What gets me is that these companies sell those LED kits but don't advise to use a load equalizer. But In some instances the equalizers aren't required as with the newer Harleys with BCM lighting controllers. The BCMs only need to be reconfigured for LEDs is all, no additional parts or modules.
So, my Badlands Load Equalizer III module arrived late last night and I felt the need to immediately install it. Just to be clear, my blinkers WERE flashing improperly so the indication for the module was correct as indicated by SCHMIDTY. The module went in easy and corrected the blinker issue as well as my "red key" problem. Thank you all for the great recommendation.I just ordered the Badlands Load Equalizer. I will update as soon as I install it. Thank you for the information.
