1 - 3 of 3 Posts
trying to remove the ecu off an 07 ultra classic the allen bolts only turn and dont back out (yes im turning it the right way) anyone else had this problem and if so hoe can i fix it
Thanks
I just went through this last weekend. I had to take the entire mount off. Then I took it to the vice and got the first allen bolt out by putting vice grips over the plastic and putting some pressure on the captured nut. The second one I was not so lucky, it wouldn't come out that way. I ended up doing the same thing but I heated the allen wrench with a torch and let that heat transfer to the bolt then it came out.
To re-mount the ECU I put 2 size 10-24x2" allen bolts in from the back side to use as studs. You can put nuts with Locktight on the allen bolts from the front and then mount the CPU and add another nut to hold it together, I used Nylock nuts for that.
Thanks for the help
I called the dealer and it is warrented work so im gona let them deal with it, got the fuelpak zipp tied on for now
1 - 3 of 3 Posts
