Try the infinity Kappa 6.5 or the Polk 6.5
Biketronics 7.1. Lifetime warranty
But they needed to be pushed by a good amp. Fosgate 300x2. $150.
Jax,Biketronics 7.1. Lifetime warranty
Welcome to the forum, but a bit of bad news. It's ok to go with the speakers you want, but if you are going to 6.5 in. you will need the adapters. Your bike carries 5.25's as far as I know.Jax,
These Biketronics speakers are in the Porsche price range; way out of my league for my intentions. I did mention that I didn't want to spend big bucks. Somewhere around $70-$100 per pair is what I'm thinking. Actually I think I found what I am looking for; the Polk DB651s; about $65.00 for the pair. Like I said, nothing too serious in the cost department. Just playing around.
This will give me something to do (weather and temps permitting) to the bike during my winter hibernation. I have never taken the fairing apart so this will be my adventure. It doesn't look too difficult (I hope!). I do have the H-D service manual.
I thought this bike used the 6.5". I will have to dig a little deeper. Thanks for the head's up!Welcome to the forum, but a bit of bad news. It's ok to go with the speakers you want, but if you are going to 6.5 in. you will need the adapters. Your bike carries 5.25's as far as I know.
You are correct. 2014 and up use 6.5".I thought this bike used the 6.5". I will have to dig a little deeper. Thanks for the head's up!
LOL....taking the fairing off is easy, getting it back on is a pain in the butt---have another set of hands available. And whatever you do dont let the fairing drop on your fender.Jax,
67Duce,I've been researching this lately for my 14 SG ,
I understand what your attempting but I think your results will be a minimal improvement if at all with this segment of speakers. These new head units are touchy , you need to be SURE the speakers your using match the ohm rating of the stock speakers , if you do add an amp you will need / should have the dealer flash your Boom Box to " no amp , four , six , or eight speaker " setting. The place I talked to said they would ONLY recommend there level 3 and up for the 2014's and 15's .
After I talked to them I realized my thought of using Focal R165C's ( $170 pair ) and an Arc KS 125.2BX2 amp ($300 ) wasn't going to cut it as it is what there level 1 system uses , unless I stepped up to the Focal 165AC's ( $250 pair ) they will sell a plug & play level 3 system for $700 carry out or installed. This includes a custom wiring harness which is a key item.
They also told me that they have to modify the speaker area to fit the 6.5" speakers in the 14 & 15 bikes, which tells me that standard 6.5" speakers are likely NOT going to just drop in.
While $700 sounds a bit pricey when you compare it to the HD Boom Audio speakers and amp upgrade your getting ALOT more bang for your buck ,
Sorry for the long post , just think your not going to hear much difference with the speakers your thinking about, I'd wait till you can go with a little more. The DB ratings of stock vs BOOM Audio upgrade are only 1 DB @ 60mph . . . .thats a $800 speaker & amp upgrade.
I guess I'm the opposite , when I bought mine I was fully expecting to upgrade the audio at some point , as you and I have both found those "pumped" systems don't come inexpensively.67Duce,
After reading more about these audio systems and also reading on another site about the required flashing of the stock Boom! radio if it applies to my 4.5" non-GPS radio, I decided it isn't worth it to me to go through all of this and the expense to hear "better quality" sound. So I will take a break from it all and not bother doing anything more and just enjoy the stock radio system for what it is. Spending $500.00+ is out of the question! Are those Focal speakers waterproof? They should be either marine or made of waterproof material to withstand the outdoor environment motorcycles subject audio equipment to.
The irony; when I bought the 2014 FLHX I had no interest in the radio at all. It just came with the bike. Then, after hearing another rider's bike with his "pumped" up audio system, I was blown away from the sound, and of course it peaked my curiosity.
Thanks to all for your assistance in helping me. It truly was a learning experience.
67Duce,I guess I'm the opposite , when I bought mine I was fully expecting to upgrade the audio at some point , as you and I have both found those "pumped" systems don't come inexpensively.
The Focal 165AC's can be had on ebay for $200 ,still you would need an amp to get the most out of them. They don't really say "Water Proof " but the cones are fiberglass with a butyl rubber surround , I think there fine as long as your not spraying them directly with a hose or power washer for sure.
I was told the reason for the flash is to flatten the stock Boom head units EQ , at louder levels it can cause the highs to distort. This flash is even required by Harley for BOOM Audio upgrades like adding a set of speakers.
I didn't mean to take the wind out of your sails , now that you mentioned why you became interested in upgrading your system I'm more certain your results would not be what your hoping for , just trying to make you aware before you spend your money.
Thanks for posting the pic's of your fairing and the tips on screw locations , pic's are always helpful , maybe save me some time when I get in there.
