1 - 9 of 9 Posts
2000 883H Sportster
Picture your right hand on the throttle and resting against the housing for the start/on-off/turn signal switches. Thumb knuckle and first knuckle of pointer finger make contact with that housing.
While on the interstate today, 5th gear, about 72mph, I felt a sting, like a shock in my thumb and then in my pointer finger. A couple in a row on the thumb and only once on the finger.
Rode for another 20 minutes or so and couldn't duplicate it.
Any ideas here?
Nothing on your bike could cause an electrical shock unless you put your tongue across the battery terminals !!!
Maybe a bee sting or something.
As I get older, I continuously discover that my body and my Harley are actually similar. Both seem to do odd crap randomly.
With both the bike and the body, I now look for trends. I just ignore it when it happens the first time.
Super Moderator
Wierd, because if there was a power wire bouncing around it would short to the switch housing and blow a breaker, or fuse. You could pull the housing apart for a warm and fuzzy that this isn't the case but it does sound like a ghost issue.
Try'n to behave
I have found that I get that same feeling randomly. As has been explained to me; it could just be a nerve getting a slight pinch. Happens to me occationally, and not just during one type of situation.
Discussion Starter #7
Rode it home from work (49 miles) and nothing. Maybe it was that ghost issue. It felt like a bee sting but since it was in two fingers (and no outward signs of the sting) I guess it wasn't that.
I'm also experimenting with grip angles and strengths as I get numbness or a little pain in parts of my hand. I might just have to figure out a more comfortable grip.
Amen to that.
To the OP. At the speed you were traveling, even a small grain of sand could cause that sensation if it hit in the right place.
1 - 9 of 9 Posts
