1 - 3 of 3 Posts
Kicking Rocks...
Check your grounds.. The sporty of that era is very specific on battery install.
What is the battery voltage static and have you load tested the battery...
You took cams out? Do you have adjustable rods or did you pull top end off?
5 th gear and plugs out will be the easiest to cycle the motor.
I pulled the top end off. it was a paint in the butt. it has hydraulic lifters. i did everything according to the service manual. this bike has a battery charger on it... it looks factory.
i was told 3rd gear. pushing this bike back and forth reminds me of hell week back in high school football. i'll check the grounds again. thanks broseph.
1 - 3 of 3 Posts
