1 - 9 of 9 Posts
Old Member
I'll be changing to SE 203 cams shortly and doing the breather valve as I'm getting too much oil into the air filter.
Anyone using this breather and does it work for you.
havent used one, but have heard good things about them. what makes you say you are getting too much oil in the air filter? What air filter are you using?
Tony
Old Member
Using s/e air filter and oil is coming out the bottom of filter onto the cam housing.
how old is the SE filter? I have and 02 that had, my guess is an 02 version of the SE filter with the breather holes at the bottom of the back plate. on long hard rides it would blow oil all over the right side of my bike. I upgraded the the back plate to the newer style part number 29510-05 page 542 of the p&a catalog, that vents at the top and has breather tubes that vent into the throat of the carb or throttle body. Replaced this last fall and rode all summer with no problems.
Tony
Old Member
I have the same newer style back plate as does a friend of mine who rides an 07 RK and we both have oil all over the right side of the bike,especially when over 100 MPH
ok. guess i got lucky, or i dont ride as hard as you guys do. anyway, here is another option http://www.dohertymachine.com/index.php?cPath=1 but its kind of spendy IMO. not sure how much the S&S breather is. AN even cheaper option is (i read this and havent tried it) to stick a Maxi pad to the inside bottom of the filter cover. and change as needed.
Tony
Old Member
Discussion Starter #7
Just had the S&S breather valve installed a few days ago and have put on about 400 miles and not a drop of oil so far.
COOL, glad its working for you. Does your bike blow oil when its cooler out too? Mine only seemed to do it when it was hot.
Old Member
Discussion Starter #9
Quess I'll have to wait till next summer to find out...........
1 - 9 of 9 Posts
