4
Available at
Riders Discount is the Scorpion Lock-Up Pressure Plate to add on to your existing Scorpion clutch as a direct bolt on. Included is the pressure plate, various clutch spring weights, and a clutch tool. This is perfect for high horsepower, large displacement motors!
Three different clutch spring rates are included, from stock to heavy duty. This gives you the option to custom tune the clutch for your specific needs. If you are running with a monster engine, the heavy duty may be more your style.
The Lock-Up Pressure Plate works by progressively increasing pressure to the clutch stack as the revs increase. Constructed from billet aluminum, this not only is extremely durable but looks great as well.
Made in the USA, you can be assured of quality craftsmanship by Barnett.
Available for Panheads and Big Twin engines with mechanical or hydraulic clutches. These are for use with an open primary cover or the Barnett Scorpion Primary cover (sold separately).
This is not yet listed on our website so be sure to give
Brad a call at 866.931.6644 ext.
810 or send him a message through this forum to order yours today! Is email more convenient? Write us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
