How tuff is it to remove the front forks off my Street Glide. I just want to slide them out of triple tree's. Do I have to remove the big nut on the top of tube, or just loosen up the clamps. Can't find it on You Tube.
Go buy the service manual. It will be the best $60 you spend on your bike, I promise.
True true. Then you will have all the torque specs to reassemble.Go buy the service manual. It will be the best $60 you spend on your bike, I promise.
^^^^^^^^^^^^^ :thumbsupGo buy the service manual. It will be the best $60 you spend on your bike, I promise.
Top bolts come out. Loosen the triple tree clamps. Slide right out.
I am wanting to do the same. I think just loosen the nut on top then the pinch bolts on the trees and they should fall out. Do you know the torq specs for all those bolts and axle?
