If its just the shift lever 0n the shaft, yes they are soft and junk a known problem by owners goes back years
Exactly, in 400k miles I have never had a shifter issue. First thing I do is remove the heel shifter. I see riders stomp it into first gear and then stomp it again to make sure its in gear. One gentle click is enough to get it in gear unless there is a problem with the clutch or tranny. LonsloI have never had a problem with stripped shift lever or shaft splines. The way I see some people stomp on them, it's no wonder they get stripped.
Drag Specialties makes a steel replacement for the lever.I have a 2014 Electra Glide Ultra Limited...just hit 30,000 miles and had to install my THIRD set of a Shift Lever and Shaft as they keep stripping out making my bike unable to shift.
Is this a common problem that Harley Davidson is ignoring?
The levers are soft, sloppy is because it's already partially stripped. They are not hardened and the shifter shaft is, when they get loose (the Allen bolt) it starts destroying the lever. Depending on what model you have its a take off primary to replace.
1994 FLHTC…Im original owner…I never had a problem with the front shaft and heel toe….back at the transmission, a lot of work…mine gave up at 48,000 local miles despite constantly checking/ tightening…this is where I pinned it …trans shaft was pristine, lever stripsHere's the deal...
The hole is drilled to reset the bolt going through to the threaded side and will bind up because there's not enough space between the bolt and the side of the hole to tighten it down (you will start bending the bolt)
Easy fix is to get a slightly longer bolt and a washer. That's what I have done. I have thought about trying to drill out the hole on the non-threaded side to give it a little more play, but I'm lazy.
