I had a set of Slipstream Heated Grips P/N#56100027 installed on my 2015 Ultra Limited. I was not happy with the switch housing on the left grip so I decided to see if I could correct the issue. Long story short, I removed the left grip from the handlebar and disconnected the internal wire from the grip. Everything that I have read has said the end of the wire/connector should extend past the end of the handlebar, it doesn't, it is about 5 inches from the end of the handlebar, I have a mechanical grabber that I am able to grab the end but it does not want to come out. I have removed the front fairing, which is pretty simple to do, but I cannot locate anything that may or may not be the wire that connects the left grip to the right grip. Has anyone had this issue?
Thanks!
Thanks!
