1 - 12 of 12 Posts
Change the .txt extension to .htm (forum wont let me upload it as a htm file)
Discussion Starter #2
Now available as an android app from Google Play.
(Click on button to download)
Cross reference sparkplugs for your Harley Davidson across major sparkplug manufacturers. Simply select which Harley engine you have in the dropdown box, then select which sparkplug manufacturer you wish to use. The application then shows the part number for the correct sparkplug for use in your bike.
Sparkplugs listed are for engines in stock configuration. Aftermarket heads, high compression ratios may require a different heat range plug than stock.
For Android only.... no iPhooony
Depending on interest, I may add other items to the program... like tire sizes and other maintenance items. :dunno
It is useful the way it is, and I would also like to see a choice to show all the plugs for the selected engine instead of having to look up each one individually.
Discussion Starter #7
I might be able to do something about that. :thumb
Discussion Starter #8
Gypsy on Parade
I just stumbled across this thread. Cool app. Thanks Kainam.
"Ain't quite right"™
Much appreciated.
Discussion Starter #12
1 - 12 of 12 Posts
