1 - 2 of 2 Posts
Lowest Price, Guaran
Leather is very strong, but heavy and somewhat stiff. Textiles are light and flexible, but this comes at the expense of some abrasion resistance. The Speed and Strength Seven Sins Leather/Textile is a hybrid jacket that uses a combination of these materials to provide the the best of both worlds.
Premium cowhide leather covers nearly the entire front of the Seven Sins jacket, as well as the shoulders and outer arms. Other areas like the back, sides and inner arms use a very tough and flexible textile called AR-600 textile. The textile blends well with the leather and it is easy to mistake it for a full leather jacket from the front. This blend also helps aid ventilation, with perforated leather in the upper chest providing air for the front and large zippered vents in the rear allowing hot air to be pulled away from your back. Impact protection under the shell comes from CE-certified armor in the shoulders and elbows. The back features a dual density protector that is not CE-certified, but can be upgraded. Overall, the hybrid construction works well and results in a jacket that is safe and very comfortable to wear.
If you’re interested in the Speed and Strength Seven Sins Leather Textile Jacket, you can get more info by contacting Brad through this forum or by calling 866.931.6644 ext. 810. You can also feel free to send an email to FORUM at RIDERSDISCOUNT dot COM if that’s more convenient, and we’ll get right back to you!
The Speed and Strength Seven Sins Leather/Textile jacket is shown here in black. It is also available in White/Black and Stealth, which has blacked out logos.
Leather covers the front, shoulders and outer arms.
AR-600 textile covers the back, sides and inner arms. Note the large zippered vents running down the back.
1 - 2 of 2 Posts
