1 - 3 of 3 Posts
There is an oil leak in this area. What is the best way to access it to see where the leak is coming from? Thanks!
Update: I added a picture by pasting the URL but it didn't work. The leak is in the area of the speed sensor.
If you're talking about the VSS it should have a one screw. once screw is removed it should pull out. It will have an O-ring on it that most likely needs to be replaced, or you can try adding a little silicone around it.
1 - 3 of 3 Posts
