1 - 2 of 2 Posts
Ok, I added a chrome speedo cover last weekend, and when I buttoned it back up my high beam and oil indicator lights don't work. Anyone know if the lights plug in and are replaceable? Turn signal indicator lights work fine, so I know there's juice in the harness. :confused:
Just passing thru
Did you disconnect the battery before you did the work? If not you might have blown the headlight or other fuses. Check them by pulling each fuse out one at a time and looking at it. The indicator lights are LED's and I doubt it blew. Good luck.
1 - 2 of 2 Posts
