1 - 5 of 5 Posts
I have a 2015 750 with a little over a 1000 miles on it. I was riding over the weekend and my speedometer when from 50 to zero and then the check engine light came on after. This happened a couple of times. Has anyone every experience this problem with a Street and if so, what was the issue & cost with repair? Thanks!
Sounds like a loose connection. Check all wiring to the speedometer area. Also check the ground connections., make sure battery cables are tight at both ends. That's a few places to start looking. Do you have the FACTORY SERVICE MANUAL?
If not get one and check over the wiring diagrams.
Does the speedo go through the normal "sweep" when the ignition is turned on ? Any speedo engine light to indicate stored codes ?
Asylum Inmate
If you happened to be riding in the rain or had just washed it. It's a failure of the speedometer seals
Sent from my iPad using Tapatalk
I had this happen to my 03 RK and it was the Speed sensor. Took it out, cleaned it off. ok for a day till it got hot and then it failed again. Changed it out 3000 miles ago, all good now.
1 - 5 of 5 Posts
