1 - 3 of 3 Posts
so the bike spin when i start was work (part time ) but no at all now it has a new jack shaft and pinion gear ... when i hit the starter bottom with no jack shaft id in the coupling doesn't spin as fast as starter ... what my issue starter shaft, starter clutch or other end of coupling ? i really diidnt wanna pull oil tank but looks like that the what im going to do
Sounds like the starter over run clutch is bad. Gotta remove and dis-assemble the starter to replace it.
1 - 3 of 3 Posts
