1 - 6 of 6 Posts
Hi folks.
I'm looking for some help. My sporty has a fuel leak. It looks like it's coming from the fuel valve. Is there a rubber gasket or seal of some kind that could be gone, or should I be looking at replacing the entire valve? If so, where should I get the parts? The bike was laid up for about 4 years, so I'm thinking dry rot might be the issue here. Everthing else is done (ie: carb cleaned, new tires, pre-season service, etc.) so it's killing me not to be able to ride! lol
Thanks.
Keith
I'll second the Pingel petcock if you go with the replacement route. So much easier to use, especially if you do any riding with gloves on.
Thanks!
I just had another look at the bike a few minutes ago, and determined where the leak is originating from. There's a small hole behind the gas line (at the bottom of the petcock), which is part of the mold of the petcock - that's where the fuel is dripping (see picture). It almost looks like it might be a vent hole or something. Could this indicate a ruptured diaphram?
Also, this might be a dumb question, but if I was to upgrade to a new Pingle petcock with a higher flow rate, wouldn't that mean the bike will harder on gas? What is the benifit of a higher flow rate? Sorry to be so ignorant on this topic. lol.
Thanks.
Keith
Discussion Starter #4
Thanks for the help!
I just ordered an OEM replacement vacuum fuel valve from the dealer. I was looking at the ones on J&P Cycle (which were much cheaper), but I wasn't comfortable plugging the vacuum line to the petcock, as instructed by the manufacturer. Maybe it's not an issue, but I didn't want to run into any other problems with this right now. The sooner I can get on the road, the better! lol
As for the installation of the new fuel valve, is this something I should get the dealer to do, or is it an easy install? Is there any kind of sealant that has to be used, or is it a dry fit?
Thanks for your help!
I should have the fuel valve tomorrow so I'll give it a shot tomorrow night.
keith
1 - 6 of 6 Posts
