1 - 9 of 9 Posts
Sportster Fan
I currently have aftermarket slip-ons and stock air cleaner. I am thinking of upgrading my air cleaner but instead of purchasing an expensive tuner, thinking of a plug and play ViED.
Anyone installed Outlaw stage 1 air clearner and ViED fuel management? What air cleaner did you install? How is the AC and ViED working out for you?
Asylum Inmate
I have K & N air filter and slip ons from Rush.
I went with Xied on my 12 FLSTFB and have been real happy. 20 f lower on temp with IR Gun.
Sportster Fan
Does the XiED still run lean? I was told the ZiED is adjustable meaning you can still fine tune AF, but both are good plug and play fuel management sytems. Thank you
XIEDS money well spent, plug and play. Running SE A/C kit, Cycle Shack 3" and 20F oil temp drop.
Asylum Inmate
They rich up about 7 percent except WOT which runs the map.
Sportster Fan
Discussion Starter · #8 ·
XiED appears to be the more popular install. I purchased the ViED which is also a plug and play similar to the XiED but can be fined tuned, if needed. I believe both XiED and ViED works the same so good to know there are not issues with both intake and exhaust upgrades.
Thank you.
Fat Guy on the Ultra
The xieds have been out longer, all they do is put a resistor, or variable resistor for the vieds, inline of the o2 sensor and ecm, tricks the ecm into thinking its running lean and adds a bit more fuel over the entire fuel table.
1 - 9 of 9 Posts
