seeing if any one would be able to help. Have a 05 Road King with a starting issue. Originally bike was giving me an issue starting making no noise when engaging the start button....i jumped it from a car for several hours and eventually the bike turned over and a road around to get a charge for the following ride. When I came back to start the bike 3 days later there was no clicking/ noise from the start button. Eventually bought a new battery to eliminate that issue, bike started once fine. since then tested battery for charge and load, checked fuses & start relay, removed tank and checked for continuity at the wiring harness and bars which all have checked out fine. I jumped at the starter and I get the motor to crank but not turn over do to high compression motor. Any suggestions thanks.
