1 - 6 of 6 Posts
I just upgraded from a M8 107 Deluxe to a new 2020 Street Glide Special. I love the bike but there is one slightly annoying thing. There is a lot of engine vibration from around 1500-2000 rpm. No vibration at idle.None at acceleration. It is smooth downshifting above 2k rpm but when decelerating (off the throttle and engine breaking) in the 1500-2000 rpm range there is a lot of vibration. I thought it might be the clutch but it happens in neutral if reving it in that range as well. I talked to a service guy at a Harley dealership and he said that was normal.
Is this normal for this model?
Look at the exhaust system to see if it is hitting anything.
You can try another Harley-Davidson dealership . . . you don't have to take it to the dealership you purchased it from. Good to get it documented and in Harley's system. Utilize that two-year unlimited mileage warranty that comes with your new bike!
All mounting bolts tight? Just because its new doesn't mean it was assembled properly.
Sick when dealer tells you its normal after paying a lot of money. Have another one on floor ask them to crank it up, oh wait this one doesn't vibrate....
Reactions: 1/2 Ton
1 - 6 of 6 Posts
