Sumping Again
978 Views 9 Replies 7 Participants Last post by  Dave63
1 - 10 of 10 Posts
I'm sure there is someone here that can help with that
Sent from Motorcycle.com App
You need to reset the checkball in the pump and then replace with a new ball. You're also supposed to clean your oil tank about every 10k to prevent skank from getting from tank into pump and ball seat.
Search. I posted a pump cutaway and instructions.
You said skank....and ball seat. :laugh
Does the ball get worn??
It does when you tap on it to refit seal on seat.
Its a $1 part.
Those damm skanks always getting worn out. :(
Skank on the tank?
That might require a shot.
It must be one of those technical terms that Dave likes to use sometimes.
1 - 10 of 10 Posts
