My 2006 FLSTCI started to make a new noise on a ride I was on and it bothered me. I know all harleys make noise but this one was new and I did not like it. A few blocks before I got home it started running bad and the oil light came on. I just checked the oil at the last fuel stop an it was fine but now the tank is empty. No sign of any leaks. I pulled the drain plug out of the crank case and found the oil. The first thing I think is the cam chain tensioners have gone and taken out the oil pump. I opened up the cam chest and to my surprise the tensioners were perfect. Something is wrong so I keep going. When I got the cam support plate cams and oil pump out it was very clear wht happened. The rear inner INA cam bearing was gone except for 3/4 of the race tht was now turning in the hole with the cam. I have been doing research on the failure and have found out it's not that uncommon. If you have changed your own cams you probably had the parts guy tell you that you need to upgrade to torrington bearings even though the INA bearings come in the kit for the cam change. As it turns out this is just another issue of the MOCO bean counters saving a dime and the customers who lay down good hard earned money to own a part of the legend have to put out more cash to cover their mistakes. Thanks for listening, I had to get that of my chest.
James
James
