Did a bar change...everything works fine but the engine light is on with codes P1510/p2138 and can't clear them can I get some help on this ...don't really want to take it to the slealership.
If you change it, buy the one that has the CVO part number. It doesn't have the plug coupling on it and the wiring is significantly longer. It should allow you to have solid wiring all the way through the handlebars.Thanks....I'm going to try that this weekend but I'm sure the that did the bar swap, soldered the wires....this is driving nuts.
.cause I'm planning a trip easter weekend. ...maybe since I'm removing it,should I just go ahead and change the TGS..?
Again everything works fine. It's just clearing the codes.
If you change it, buy the one that has the CVO part number. It doesn't have the plug coupling on it and the wiring is significantly longer. It should allow you you not have solid wiring all the way through the handlebars.
