1 - 20 of 28 Posts
Flat Land Redneck
Are all tb cleaners pretty much equal, or is there any particular one to use or stay away from? My 06 RK is getting a little dirty. Any advice and/or opinions will be much appreciated. Thanks in advance.
I use the store brand carb cleaner. O'Rielly AutoZone ...usually have the better sales on them , pick up a case at a time on sale .
Wayward Son
Webco is cheap. :D
Seafoam or Lucas.
Wayward Son
They say if you die with a penny in your pocket you died broke.
I call it good financial planning.
I use 1st Ayd brake clean, easy on plastics and rubber parts but cleans oil, varnish and soot well.
Am I right in assuming that we need to stick with throttle body cleaner here? Long time ago on autos you could get by with starting fluid but then the staring fluid ruined one of the sensors in the throttle body. Anybody remember this or did I dreamt? So throttle body cleaner only right? Thanks
Wayward Son
Am sort of confused. Are we talking internally or externally?
Wayward Son
Thanks.
Stand by my suggestions of Seafoam or Lucas.
Glad to be anywhere
In the old days we would slowly pour a coke bottle of water through the carb while the motor was being goosed. . . . . Or was it coca cola? I forget
Anything cold would flake off the carbon. ATF was used so that it would help to flush the carbon pieces out and not scar the cylinder walls and rings .
Glad to be anywhere
And if you didn't know the white smoke was coming, it could be somewhat disconcerting. :wink
Keep on Ridin’
Y'all are talking about two different things. That being cleaning the throttle body (the original question), and decarbonizing the combustion chamber. Need to be very careful with the latter, especially on a smaller engine you care a lot about, i.e. your Harley motor. Probably not necessary on a F.I. engine. Seafoam or other good fuel additive should take care of that. A gunky throttle body needs to have the throat walls ( or venturi ) and throttle plate hand cleaned using a good solvent such as carb cleaner and a small, stiff bristle brush. The cheap stuff is fine, IMHO, although I certainly defer to Schmidtys' opinion and recommendations in all thing Harley.
Wayward Son
If caught in time, done regularly, would`t a good fuel additive avoid the need for a more physical and involved cleaning?
FI is the thing now. Doubt I will ever own an FI bike. But still trying to learn.
The oil mist coats the walls and body.......... collects dust and things........... need to clean it off every now and then . :smile
1 - 20 of 28 Posts
