1 - 20 of 20 Posts
Doc
Just diagnosed with Tendonosis in my right arm and looking for some relief without droping a c-note or more. Looked at Throttle Boss/Cramp Buster stuff and "most" of the reviews are good but occaisionally I'll come across one that warns of unintended acelleration.
Any comments/recommendations on products that work and or cautions?
Hit it she goes boom
Had one on my sporty, would recommend it to anyone, never had any unintended accel. I think they were Kuryakyn. Nice grips too, cut down on a lot of vibration.
Turgid Member
I've used a cramp buster for a couple of years now and it's simple and works as advertised. I like it and there's no way for it to malfunction.
Rider
One trick I use is when I'm putting around town, I slide my hand right up against the switch housing and avoid the rocker. If it does get in your way frequently, you should readjust it.
Señor Member
Never had a problem with it.
I use them on all my bikes. I found one that is rubber and quite a bit smaller than most of them.
On my Roadglide it is built into the Avon grip.:thumbsup
Call me Gig.
I just got one of the clip on ones about two weeks ago. LOVE IT.
EVO RULER
Last burnout I did leaving the bar that's what I told the cop caused it!!!:)
Mississippi Cajun
I have the Kuryakin one on my bike. Handy when I don't want to use the cruise control. I could see how you might get a slip up and produce some unintended throttle boost, but once you get accustomed to it being there, you won't have the problem.
I took mine off (Kury). I find that I have better throttle control at low speed, when using the friction zone, without it.
Wasn't bad on the super slab, but the payoff wasn't worth it to me.
Señor Member
I don't know what you guys are talking about. Mind clueing me in on what this thing is?
Señor Member
It's a doohickie that mounts on the end of the throttle grip - like a small paddle. It's intended to relieve cramping b/c you can rest your outter palm on it and don't have to grip the throttle as much.
Thanks, 9'er. :thumb
Got one, love it! Had the Crampbuster, clip on version on the Honda. Occasionally, I would hit a bump and goose it a little, aside from that no issues.
I've considered one but I get the feeling they won't so well with my grips and I like my grips. Problem is it looks like these crampbuster things are supposed to go on a rather flat grip and mine are somewhat football shaped. Being a little fatter in the middle and skinnier on the end with a knob. Just looks like it wouldn't work as well. Like these...
Just make sure you don't install it too high. Or you WILL get unintended acceleration. The first time I ever put one on I almost wrecked before I got 2 blocks down the road. I had it too high. I adjusted it so that during normal riding I don't even notice it but if needed I can just let go with my fingers and hold the throttle with my palm.
No Whining
I have the silver clip on one. Never had a problem, but I just rotate it backwards out of the way when I am not using it, pointed straight down.
1 - 20 of 20 Posts
