I use the omni cruise and I like it a lot very easy to use quality billet aluminum good warranty as well.
did you add the .com after barefootwillies?Your link doesn't go anywhere other than results of a Frontier search for "Barefoot Willies".
I could be wrong but that star screw is a friction hold on a ring and if you constantly keep it set and twist the throttle either way you are wearing a groove on that friction ring and it will eventually split and you won't have a throttle. I've seen this on a Honda that had a throttle lock that was attached to grip the plastic sleeve. Glad it wasn't my bike.After riding with Linkert carbs for so long, I now just set my star adjuster so that the throttle spring can't return the throttle. This simulates the Linkert style throttle response and also makes the throttle lock a non-issue...it stays where you put it. Twist the grip to accelerate, twist to decelerate. Who needs automatic throttle returns anyway?
Dave
I've been riding that way for 10 years on my old 73 FX and 6 years now on my XL. Never has a problem and never saw a groove on the throttle sleeve when servicing it.I could be wrong but that star screw is a friction hold on a ring and if you constantly keep it set and twist the throttle either way you are wearing a groove on that friction ring and it will eventually split and you won't have a throttle. I've seen this on a Honda that had a throttle lock that was attached to grip the plastic sleeve. Glad it wasn't my bike.
I got mine on e-bay for less. Look around, you'll find it cheaper. The Barefoot Willies is the same concept. Snap on, snap off.Dr cruize looks o.k. but, darn, they want $14.99 shipping too. Should not cost more than a couple of 50 cent stamps!
