Tire Balancing
3585 Views 15 Replies 11 Participants Last post by  SCHMIDTY
Just had a new Dunlop E3 front tire put on my RK. It took a ton of weight to balance out. Not long ago I had a back tire put on, it balanced out perfect with no weights. :dunno
1 - 16 of 16 Posts
Is the dot in the right place?
I will go to balance beads on the next new tire as my first tire when the bike was brand new had a lot of weights clamped on.
Where's the beef, I mean dot?
There is a dot of paint that goes below the valvestem .
The dot is on the valve stem. It took about a 4" strip of weights to balance out.
The dot is close to the valve stem, but not directly in line. It's within an inch or so.
It needs to be lined up directly under, close is not good enough . :)
I just went out and rechecked it. It's on the money. That's why I just edited my original post. Thanks for everyone's advice.
Some tires need more to balance them than others. Run it a while then recheck it if you want to . :)
You can check it on the bike. Just jack it up, spin the tire, see where it stops most times.
I have about 70 miles on it and it runs out smooth. So maybe it's not a real issue. I'm probably just making a mountain out of a mole hill. I appreciate everyone's advice and/or opinions. Y'all ride safe and enjoy. :ride
I use balance beads...
+++1 on this. I was leary about em, and when my new front wheel came with em, I swear by em!!
so far i like the beads. still in the testing area. have rear tire starting to look cupped. so just watching as i go
Google RIDE ON tire balancer/ sealant, mine took a lot of weight, still had a slight vibration, installed this, smooth as silk. No it's not like slime sealant
ride-on is great stuff. i'll use it on every tire i put on from here on out. it is smooth as silk. the real problem with the beads is after awhile adding air lets water enter the tire and will clump the beads losing all balancing action.
Bought a " NEW " 28 spoke chrome wheel from Hd, took a ton of weights to balance and of course the dealer says oh that normal...I call BS..but rode on it for awhile..rode like crap....got tired of it..pulled the dumbflop off put on a Michelin com II with 1oz of dyna beads...and guess what ???? yea..you got it..it rode soooo bad you couldn't hardly hold it on the road...put another 1oz pack of beads......little better.....put another 1oz pack of beads still crappy..........took the new tire off.. put the wheel on a Habor freight tire balancer.....the wheel was 3 1/2 oz out of balance..looked like they forgot to machine part of the wheel...sooo went to the heavy side and ground out 1 1/2 oz of metal from the wheel..any more grinding, drilling might have been to much...got it down to only 2oz out of balance..so then I ground and scuff up the metal and added exactly 2oz of JB Weld to the inside of the wheel.......perfectly balanced !!! put new Mich. Com II back on ..needed " NO " weights...balanced perfect, rides perfect.....moral to the story...HARLEY will sell you a pile chet wheel .........
All those weights on a wheel look like shit man !
When I was doing that I never put more than 3oz on a wheel. If it took more I re-broke the bead and shifted the tire on the rim. We had a good electronic balancer that gave a pinpoint where the wheel and the tire balanced regardless of the dot on the tire.
IMO. The wheel is usually the balance problem, not the tire. I've spun a lot of wheels sans tires and weights and they're never in balance ! Especially spoked (laced) wheels !
1 - 16 of 16 Posts
