1 - 20 of 104 Posts
I tuned a breakout using the screaming eagle street interface and on the dyno the bike will only pull to 114 mph. which it reaches at 5700 rpm's in 4th gear.
I did a couple searches and can not find any threads on this which I find surprising.
any one have any insight if this is normal and if it can be disabled
thanks
Why are you dynoing in 4th gear? :loco
And there is no "speed limiter" on Harleys.
There is a rev limiter. It helps to keep people from blowing up their motors.
You should get proper knowledge of the machine your supposedly dyno tuning. Good way too cost yourself a ton of money.
Now go to FNG section and introduce yourself.
lol, I promise it would not pull past 114 in any gear
and please enlighten me why a 4th gear pull is wtf and crazy and stupid??
These guys don't know what they are talking about amigo. Especially that Schmidty character. Hell I think he's a retired dentist. Here's what you do:
We are talking about a breakout right? Remove the seat, then remove the gas tank. Next loosen the bolts on the rear fender (DO NOT REMOVE THE FENDER!). Pull your headlight then you will find the top speed limiter button somewhere between the headlight & rear fender.
Geez fellas, can't believe you were not more helpful! :devil
Good luck amigo!
Its located behind the BCM Module, Thought every one knew that. :eek-surprise
How fast were you expecting the bike to be?
BTW, it probably would never make the same speed on the road that it does on the dyno. With no air to move through, you're just spinning a wheel.
From a Cycle World article comparing bikes. I would think they would know what they were doing so I'd assume 6th gear.
Hey Doc, does the article say if the speed limiter was on or off?
Frozen Member
When I had some dyno runs done on my bike last year the tech always took it to 4th, and in the videos I've seen thats the gear they use too. I thought it was the standard, no?
Discussion Starter #18
apparently they are all as stupid as me and didn't know the golden rule to not run a Harley in fourth gear on the dyno
I find fourth gear gives the most consistent runs and slows it down enough that you can see what's going on with the fueling
Supposed to run in the gear that gives 1:1 ratio in the transmission to minimize losses.
But you probably ran it on a Mustang dyno, so meh. :dunno
1 - 20 of 104 Posts
