1 - 16 of 16 Posts
Guys finishing up my primary fluid swap today that service manual says 82-100 lbs-ft for the 5 torx 27's. I set my socket to 90. After a few seconds I couldn't make myself put anymore on it. Just felt like way too much for fasteners that small. I set the wrench to 80 and same thing. So I just twisted em' to where I felt comfortable.
Yes the wrench is working correctly.. has this happened to anyone?
Pete
When torquing fasteners the threads on the fastener and in the threaded hole need to be cleaned , wire brush the fastener threads and chase the hole threads . Harley applies a type of locktight / sealer to many of the bolts and screws on their bikes especially on the engine , trans and primaries . If any of that locktight / sealer remains on the threads when reinstalling the fastener proper torque can't be achieved and if using the book torque spec over-torqueing will occur possibly stripping or breaking the fastener .
Those derby cover screws only need to be tight enough to seal the cover , wrist tight !
Poser Member # 99
I Agree with Schmidty and dont forget new locktite on the bolts it holds every thing together. Cleaning the threads is a must and I also use some Acetone paint thinner to clean things out threads too . I use a acid brush . paint brush or small round brushes to clean holes out with the Acetone :thumbsup
Mississippi Cajun
100 inch pounds is 8 foot pounds
remember to move the torque wrench quick and steady or you will over torque the fastener
Actually, it's 96 in lb = 8 ft lb, but 100 is close enough.
Thank you so much, I would hate to have to extract one or fix the internal threads!
Sheesh! This post is from 2011, I gotta learn to look at the dates BEFORE responding! 9 years later...:oops:
Don't feel bad 1/2 Ton, I get caught like that from time to time too !
I give the guy credit for joining our forum then actually doing a SEARCH to find the answer to his question then posting a thank you back.
I've done that too . . . just the other day I saw a post about Ronald Reagan just being elected! I wonder if he will go two terms!
Just remember, the owner who originally posted this may not care anymore, but hundreds of other people doing a search DO care. How to do this oil change isn't something likely to become obsolete anytime soon. Thanks for all the help!
1 - 16 of 16 Posts
