Turn signal module location?
43857 Views 16 Replies 10 Participants Last post by  Wingnut
91 heritage FLSTC. Anyone have a pic or a good description as to where the turn signal module is mounted on this bike? Any wiring harness mounting or routing pics would be helpful in reassembling this basket case of mine. Thanks!
1 - 17 of 17 Posts
A MoCo Service Manual along with the Parts Book , would show you with exploded views, exactly where everything goes and how it goes .
Wiring diagrams are included in them .
Both can be had from the Dealer, special order, 10 days to print them for you .
That is a big help, why not just tell the guy to get lost?
OP, you say the bike is a basket case...are you working with an OEM wiring harness?
Do you already have the turn signal module?
Well Dan, where is it located? You're the softail guru. I'll say under dash mounting bracket.
Just looked it up...It`s mounted on a bracket on the frame, up near the steering neck. The `90 and earlier have the flasher unit mounted in that location along with the circuit breakers.
But if the OP doesn`t have a harness yet, or handlebar control switches, there are several ways he can go...I think that the `91 -`95 turn signal modules may be different than the ones used `96 and later.
Okay, I see a bracket on the frame between the tank halves directly under the 5 indicator bulbs of the dash that looks like it would work. Thanks Dan!
Now where's the starter relay mount?
Try this website. Microfiche for most Harley's avaiable. :) Click on OEM parts finder tab.
Ronnie's Harley-Davidson's Harley Davidson Street Bike Parts Finder
Looked there already in an attempt to help the OP. Had some info but not complete for the 91 FLSTC.
Up by the battery under the seat.
Do you also have a `94 Softail?
That's a great website, very helpful but it doesn't have a component locator :-[
Sorry late to the party, that's where it's mounted on my 91 FLSTC. As stated a factory service manual is a great investment, add the parts manual and you have a outstanding combo.
Dan, I do have a 94 Fatboy but it's not much help to look at it as it has been heavily modified, pretty much nothing left stock including the wiring, no turn signals etc.
Right side of bike next to turn signal module, between battery and rear fender. Has a screw that holds on relay and plastic cover.
1 - 17 of 17 Posts
