1 - 5 of 5 Posts
I have a 92 flht that has a twin cam swap in it I was having trouble with the solenoid sticking witch ended up frying the started so I bought a new one and got it all in and now the solenoid is not sucking the plunger all the way in it seems to have a lot of tension on the plunger when you push it all the way in any ideas ?
Low battery volts maybe. A fully charged battery will measure at least 12.8v static.
Got all the ground wires connected ?
Hit it she goes boom
Is the wire to the solenoid getting juice?
The plunger won't go all the way in if the pinion gear is hitting or catching on the clutch ring gear. Try putting the bike in gear and rocking it a bit then pull the clutch in and try starting.
1 - 5 of 5 Posts
