It depends on how picky you are. You can swap out the head pipes or cut the cats out, but that alone is not going to do much for sound unless you also change the mufflers. Although, it may help you manage heat better.
I went from a Heritage to a FLHTC, and because of the way they are designed, you won't ever get the two to sound the same. At least not to your ears when riding. The Softail exhaust exits on the side of the bike and only one side, so it sounds VERY different to the rider than a touring bike with rear-exiting exhaust. On a Softail, you tend to "enjoy" the exhaust more yourself. But, on a bagger, those behind you get plenty while it can be fairly quiet to you. This is actually a good thing, as the exhaust can wear on you after several hours in the saddle.
All that said, there probably more options for bagger mufflers than any other H-D. You should be able to find something that tickles your fancy.
