1 - 7 of 7 Posts
Was working on carb and adjusting throttle cables after putting everything back together was revving engine and all of a sudden right front turn signal lit up and stayed on revved it up a few more times it went off then came back on now it is on and the left turn signals quit working any ideas
You have a pinched wire , shorting .
Did you have throttle housing apart? A pinched wire would take out tsm. (Turn signal module )
Depending on how high and much the engine was revved the TSM may have taken a crap. Over voltage could have damaged it. If you can't find any bad wires then I'd guess it's the TSM.
1 - 7 of 7 Posts
