1 - 3 of 3 Posts
I am running into a very weird issue with my HD 883 sportster and wondering if anyone else encountered something similar of what could be the core issue here.
Every once in a while my bike will not respond to start switch and once pressed all light's with go off. when checked Battery is good and even during the time of issue the volt's are above 13. When the issue happens, the resolution is to completely disconnect the battery and reconnect both the terminal's back and everything will be functioning normal. One another thing that I have noticed during the issue is even when my keys and kill switch is set to off the speedo meter pointer key goes little up and comes down multiple times.
I have tested all electrical load things on multimeter and couldn't find a bad part.
Please share your experiences and what could be wrong here.
thanks for your help.
Ground cable at frame is the usual problem.
1 - 3 of 3 Posts
