1 - 4 of 4 Posts
Hi
My 2007 FXDSE 110ci is leaking oil through the boot/wires from the stator. Is this primary or engine oil? Is there a way to stop the leak without removing the primary?
Hi
Primary oil.
You can pull up on the "lips" of the seal, clean well with Diskbrake cleaner, then coat with RTG .
It's a common problem...so do not stress too much. Silicon sealer may fix it, but entirely depends upon how clean things are and Lady Luck. Ideally you should pull the primary and chain and do it from the inside but that's a chit load of work for one small leak.
1 - 4 of 4 Posts
